Why are my string loops doing this?
Postby BK in Wisconsin on Fri Jul 30, 2010 10:31 am
Why are my string loops doing this? 2 of the last 3 strings I've made are like this.
BK in Wisconsin
Re: Why are my string loops doing this?
Postby Hornseeker on Fri Jul 30, 2010 10:39 am
Cause you suck at string building.... :? :?
:mrgreen:
:mrgreen:
:mrgreen:
Just kiddin man... I'm sure you'll get a good answer, but I dont build endless....so...could only give a smart ass answer.
Don't confuse me with facts, my mind's already made up
Postby BK in Wisconsin on Fri Jul 30, 2010 10:43 am
Hornseeker wrote:Cause you suck at string building.... :? :?
yes...yes I do :roll: :roll:
BK in Wisconsin
Postby rwsbow on Fri Jul 30, 2010 10:51 am
Don't know if it is the same reason as what was happening to mine were about a year ago, but I was not keeping enough tension on the server after spinning the arms, allowing the initial loop serving to "relax" slightly and allowing the "gap" to appear....started paying more attention to the initial wraps after spinning the arms...VOILA...GONE!!
Just my thoughts...hope you find out for sure what it is...sure sucks when that happens..I know..I've done a few (well, even more than a few) :cry: of them....
""" I HATE it when the voices in my head start talking about me behind my back!"""...Bender, Champion Archer and 21st Century Philosopher....
Postby AROMAKR on Fri Jul 30, 2010 11:28 am
I agree not enough tension on the serving tool.
Bob
AROMAKR
Postby Jon in Montana on Fri Jul 30, 2010 12:39 pm
AROMAKR wrote:I agree not enough tension on the serving tool.
Bob
I concur!
I'm with E, though, in that I don't make endless.... But I had this problem on my serving before - adjusted tension and everything is good.
Jon in Montana
Postby LBR on Fri Jul 30, 2010 4:08 pm
Yep on the tension--at least that's my best guess. I run mine pretty tight, and as far as I know haven't had that happen.
Chad
LBR
Postby BK in Wisconsin on Fri Jul 30, 2010 4:40 pm
Ok...thanks guys!
I'll tighten the server up a bit for the next one.
BK
BK in Wisconsin
Postby Crooked Stic on Fri Jul 30, 2010 6:05 pm
I aggree on the tension. When I made endless strings I kept it tight enough that it took a fair amout of effort to wrap the serving. I guess you can get it too tight but I have not found out what that is yet.
Postby jeffhalfrack on Fri Jul 30, 2010 6:32 pm
I don't mean it in a bad way, maybe,,,, put the beer down while serving???,,,, my vision in my left eye got better once I started takeing the spoon out of my coffee cup. just a thought, I use thin super glue on all my b-50 serving, keeps it tight JEFF W
