All right folks, I'm in the prototyping phase again. I'm developing a shorter D/R, forward riser, three piece longbow. I'm thinking 58" nock-nock. I drew up a riser that is 14" long. The bow will be built with 1.5" stock. My limb wedges are 8.25" long. I roughed out a pine riser this morning, but forgot to take any photos. I'll get you guys caught up tonight! I've got one of the pirate riser/limb drilling jigs. I plan to lay the mock-up riser on a piece of butcher paper and start drawing limbs until I hit on what I think is right. I'm thinking around 3" deflex, and bring the string nocks back to just above the back of the riser in reflex. I don't know what my limb pad angles are, because I just drew it out until I thought it looked right. I will know more tonight when I start drawing limbs.
1. What kind of limb pad angle are you guys thinking on this? I'd like to be able to make recurve limbs for this model as well.
2. The holes in my drilling jig are spaced 2.5" on centers, but I was thinking of going 2" between the insert and alignment pin, since the longer spacing is crowding my grip area. What are your thoughts on 2" spacing?
3. How short can I go on the limb pads?
4. The riser will be action-wood from Kenny. I plan to lay up the riser with a 3/16" phenolic I-beam. The riser depth will be 1.25" where the limb bolt insert will be. Is this enough depth?
5. Any good tips in general regarding this project?
I should get my riser block, wedges, and take-down hardware today from Kenny, so I will probably answer some of my own questions when playing with the parts. I'll post some photos of my riser tonight.
